Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
How do I repair a blank but not cracked screen?
I dropped my phone, the screen did pop out but is not cracked. I placed the screen back in. It will ring and works as it should but I can see nothing on the screen still. I hope I have just placed it in wrong.
Score -1
Add a comment
1 Answer
Chosen Solution
Hey Crystal,
It sounds like the display assembly was simply not attached correctly. The connector must be installed perfectly, so check out this guide to make sure you attached everything correctly. You might want to consider spraying some compressed air over both parts of the connector to make sure that no dust or dirt gets in the way.
Hope this helps! Good luck!
Add a comment
Add your answer
crystal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 710
