0
Score
Avatar
luisfcosta
Asked
Multiple problems after LCD replacement
History
This question is archived. No new answers are allowed, and only the question's owner may edit it.
Hello. I've recently replaced the LCD on my unibody MBP 17'' 2009. It's the second time I had to do this and the last time there were no problems.
I followed the guide on iFixit.
What happens:
- OSX will not boot on any medium (disc, dvd (L, SL, Lion) and USB)
Windows
- Boots while connected to A/C
- After successful boot (while on AC), if I unplug the cord, either it freezes or the airport card stops working (connection becomes limited, then no networks are found - plugging back to AC doesn't solve anything)
- When booting without being plugged (on batt) it hangs past the windows boot logo. Sometimes it goes up until the point when the mouse pointer show up.
Linux
- Boots and Installs.
I have tried reseting the SMC, PRAM.
When I try to boot OSXin verbose or safe mode the boot process stops at either
- AppleIntelCPUPowerManagement:ready
or
- Broadcom (etc) - wireless card line.
At one time I got the following error report:
https://docs.google.com/folder/d/0B9rBwc...
(pictures are a bit shaky, sorry I haven't been able to get to this screen again w a better camera)
I'm thinking it's either an EFI problem or something to do with power management. I don't believe I've gone near any of those components (except for unplugging the Display cable near the magsafe port...)
Any ideas?
Thanks,
_Luís
Edited by: iRobot ( ) , machead3 ( )
Sorry, I forgot to add that I have tested the machine with different compatible ram and that I ran AHT (apple hardware test) four times without any error reports. Is there any way to update/flash EFI withou OSX? _Luís
luisfcosta,
Have you been to and looked through the Boot Camp Support pages?... I think you may have a corrupt power management extension, or corrupted MBR - master boot record =8^( none of your OS X partitions work. Can you access a OS X system from a different valid HD disk to eliminate a true hardware problem?
machead3,
I took the disc out and tried to boot from DVD. Still no joy. Plus, would that impact the way computer behaves depending on wether it's connected to a power source or not?
luisfcosta,
I'm not getting the big picture. You say Linux - Boots and Installs. Which makes me suspect it's software not hardware. Are all these systems on different disks, partitions on one HD?
machead3,
Post Answer
Add Your Answer
