Score
Avatar
ramon vale
35
Asked
type of power supply
History
I would like to know that I have that font installed on this motherboard Supero X7DWT for carrying two 20-pin connectors, and not whether an adapter for the two would serve me.
Update
then I want to say that only connects the jwr1. I have a 850 watt atx power should serve me then.
Edited by: ramon vale ( )
Post Answer
Score
Avatar
oldturkey03
88.3k
Answered
Accepted Answer
PermalinkHistory
ramon vale, the manual for your motherboard states that "You cannot use both 20-pin power connectors located at JWR1 (the right side connector) and JWR2 (the left side connector) as input power supply connectors at the same time. Only one connector can be used for input power supply to the motherboard at one time. For proper use of these proprietary PWR Connectors, please customize your PWR cables based on the Power Connector Pin-Out Definitions listed on Page 2-14". You can download the manual from here. Hope this helps, good luck.
thank you...
ramon vale,
You are welcome ;)
oldturkey03,
ramon vale,
Yes, that should work well for you.
oldturkey03,
thank you very much again.
ramon vale,
Show 1 more comment
Add Your Answer
