0
Score
Avatar
NARAYANAN LAKSHMANAN
517
Asked
Should we consider the logic board capacity also
History
I intend upgrading my HD to 1TB but my hard ware engineer in india suggests my logic board will not support,I will be obliged and thankful if someone clarifies,my comments remains unanswered please look in to it.
Edited by: NARAYANAN LAKSHMANAN, ABCellars, Brian, and oldturkey03 ( ) , NARAYANAN LAKSHMANAN ( )
Thank you for the wonderful tip,i intend getting it from u.s and i hope to get it by the month end,after completion shall keep you informed.Thank you very much
Post Answer
Score
Avatar
Owen Cunneely
2k
Answered
Accepted Answer
PermalinkHistory
What are the last 3 digits of your serial number? I have put 1 TB drives in MacBooks and MacBook Pros dating back to January 2006 and had never had any problems. I install Western Digital blue and black hard drives. I have never heard of any capacity cap on the logic board for intel MacBook Pros. You could even put n OptiBay in and have 2 x 1 TB hard drives. I would make sure that the hard drive is compatible with a standard SATA connector, is a 2.5 in drive, and is not taller than 9mm. You will also need to format the drive for OSX and install an operating system on it. Tell us what you are thinking about getting and I can tell you if it will work.
Hope this Helps.
serial number W8934A1F66D,I intend buying 1 TB HARD DRIVE WESTERN DIGITAL SCORPIO BLUE HARD DISC DRIVE 2.5 INCH/SATA3GB/S/5400 RPM 8MB CACHE.KINDLY CONFIRM IF THIS PRODUCT WILL SUIT.I AM FROM INDIA. THANK YOU
Same one that I order. You should be fine if you carefully follow instructions and know what you are doing. Your MacBook Pro has no capacity issues. Hope you get everything working.
Owen Cunneely,
Score
Avatar
Dan
6.2k
Answered
PermalinkHistory
Your system is: Apple MacBook Pro "Core 2 Duo" 2.26Ghz 13" (MB990LL/A)
Here's the guide page for this system: MacBook Pro 13" Core Duo, mid 2009
You should not have any problems with the WD 1TB HD your system can support a 9.5mm drive
Edited by: Dan ( )
I got the hard disc as well as the 8 gb ram this morning ,i fixed it with your advice and it is working beautifully well,thank you very much i am obliged
Add Your Answer
