0
Score
Avatar
BertH
Asked
Why does my mini not connect properly to the internet?
History
Since a few weeks my macmini 1.83 Coreduo, with 10.6.8, looses the cabled internet connection.
On the switch I can see it when the lights go off. I then have to disconnect the jack in the switch and connect again. Sometimes this works. At startup the connection never works, I always have to disconnect the cable and connect again. It is not the connection direct into the mac but always the connection into the switch. I also tried the direct connection from the cable modem into the mac, same result!
I changed cables, switches, reset my cable modem, did a clean install, switched users but nothing works.
My printer and macbook pro have no problems at all on the same switch and cables.
What can cause this problem and how can I solve it?
Post Answer
2
Score
Avatar
mayer
148.9k
Answered
PermalinkHistory
Sounds to me like you're losing your settings. This can be caused by a failed PRAM battery. To test, see if your date and time are correct when you first boot up or after being unplugged for overnight. If it's loosing the date, it will also be loosing your internet settings. Here's how to replace the battery: Installing Mac mini Model A1176 PRAM Battery
Definitely not the battery, date and time always correct! Looses the internet connection even after a few hours work.
BertH,
Add Your Answer
