0
Score
Avatar
Gatordodge
11
Asked
power window cable broken
History
How to install a new power window assembly on a dodge durango. Left rear passenger window assembly.On
Edited by: Andrew Goldberg ( ) , Gatordodge ( )
what year is your durango?
oldturkey03,
1999 Dodge Durango SLT
Gatordodge,
Thanks for accepting my answer. Yes, this should work for your year and model. Good luck.
oldturkey03,
Post Answer
Score
Avatar
oldturkey03
88.1k
Answered
Accepted Answer
PermalinkHistory
Scott Tonn, you may want to try this :"First you remove the trim panel
TRIM PANEL
REMOVAL
(1) Release door latch and open door.
(2) Roll window down.
(3) Remove window crank, if equipped.
(4) Remove screws attaching trim panel to door
CAUTION: Do not forcibly pull trim panel from door, damage to trim panel may occur.
(5) Simultaneously lift upward and outward to
release retainer steps from inner door panel.
(6) Disengage inside handle linkage rod from inside handle.
(7) Disconnect power widow/lock harness connector, if equipped.
(8) Separate door trim panel from vehicle.
(9) If necessary, pull upper trim extension outward to disengage from rear door.
The you remove the water dam and the window regulator
WINDOW REGULATOR
REMOVAL
(1) Remove upper door trim extension panel.
(2) Remove door trim panel.
(3) Position glass to access the fasteners. Remove the fasteners.
(4) Disengage glass from regulator lift channel.
(5) Position glass up into door frame (rest glass on a block of wood on door reinforcement).
(6) Lower waterdam.
(7) Disconnect regulator wire harness, if equipped.
(8) Remove screws attaching window regulator to door inner panel and.
(9) Remove window regulator from door.
Hope this helps, good luck.
Add Your Answer
