0
Score
Avatar
HugoPeroni
Asked
Can I upgrade flash storage more that 768 Gb?
History
Hi:
Can I upgrade more than 768gb on a macbook pro retina display? Does it use SSD SATA III 2.5-Inch?
Thanks for the feedback
HUGO
Edited by: Adam Hintz ( )
Post Answer
Score
Avatar
Joseph
13
Answered
PermalinkHistory
At this time I'm not aware of any manufacturers that make larger chips. Take a look at the teardown here and you will see that the Retna based MBP no longer uses a user replaceable drive/RAM.
0
Score
Avatar
Eric Tang
Answered
PermalinkHistory
no, it is flash storage and is not able to be removed from all i heard..... id go with the 15" none retina, it is able to be upgraded at our will and u can remove the cd drive (if you have skills) to chuck in a secondary harddrive.
0
Score
Avatar
David Hodson
35.5k
Answered
PermalinkHistory
To answer your question about form factor, no, the Retina MacBook Pro does not use a standard 2.5" profile. It is a proprietary Apple design that will probably take 3rd parties a while to copy.
This is unrelated to your question, but why do you want/need so much flash storage? The maximum configurable 512 GB should be good for anything you need on the go, and you can always use a 1 TB or larger external HDD at home.
Add Your Answer
