0
Score
Avatar
Biang
Asked
How to change the display case?
History
Thanks
Edited by: David Hodson ( )
Post Answer
0
Score
Avatar
David Hodson
35.7k
Answered
PermalinkHistory
You can start with the display assembly guide, which will get you most of the way there. Assuming that you're trying to replace the display case and the glass/LCD are fine, you'll have to remove everything from the display case. Start with the mid 2010 LCD guide; the machines are almost identical. From there, it will just be removing small things such as display hinges and antenna cables to get down to the bare display case.
Add Your Answer
