Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Power/Lock button not clicking, difficult to press
Hi there,
Yesterday the power/lock button on my iPhone 4 stopped having that satisfying click when I pressed it. At first I thought it was just that my phone is getting old and losing the nice tactile feel, but now it's getting harder and harder to get a response out of the button.
It does still work if I press it hard enough and in just the right spot, but it seems to be getting worse as time goes on. Right now I have accessibility settings enabled so I can sleep my phone without the button.
I've read some guides on here and I'm not sure exactly what part I need (or if I need a part at all). I don't believe it's the button itself that needs to be replaced (if anything it's probably the inner mechanism), but it seems a few people have been successful in fixing this problem without replacing anything.
I don't want to take it in and pay obscene amounts of money to have it fixed and I know a few people who are good with electronics so I'd just like to order the part, but I'm not comfortable taking the phone apart myself.
Score 2
Add a comment
Chosen Solution
this is a problem of power button black dot on it . Dismantle the iphone completely.
see:
iPhone 4 Power & Lock Button Replacement
after removing all the things . you will see the power switch has a yellow sheet on the power button and black dot on it. if small black dot is not there then find the black dot and placed on power switch. otherwise change the power button flex.
Score 1
1 Comment:
Remember one thing , before removing the power button from the panel , remove the lcd also from the panel otherwise you will damage the lcd jack 99%. best of luck
by
Add a comment
I am not sure is there any way to solve this problem but i am sharing one of my friends experience after he got such kind of problems.He goes to apple store and let the Mac Genius know about his problem and he said it is a hardware defect and went ahead with the swapping process. They had some replacements in the back.It looks like the genius nicked the chrome bezel with the charger cable edge, and there is a bit of a light leak.
Here is a video of this problem solution you can check it too -
http://www.youtube.com/watch?v=DRt4Zjbx6...
Add a comment
im pretty sure it's the power button flex.
Add a comment
I'm in the same boat. As @wawan says, seems like the "flex" that makes the button feel clicky, not any electrical components. I don't see where to buy just that part or any reference to about how to fix just that item. It would be fixed by replacing the whole button and/or power button mechanism, but don't want to go through all the trouble (and expense) if not necessary.
Add a comment
Hello.
I do not know how to replace power bottom on Iphone4s. Actually. I have no any idea to replace the power bottom fix on IPhone 4s, because it is very difficult to press to open and shot down.? May I know how much it will cost to fix this problem.?
krishna
Add a comment
Now I have this problem on my windows 10 detachable laptop. The power button is hard to press.
1 Comment:
Not the keyboard the tablet itself
by
Add a comment
Have the same problem…and then i also know that the alarm wont go off (with sound) the next morning :-( So i sold my iPhone 6 and bought a new iPhone X…the problem NOT solved :-(
Add a comment
Add your answer
Rara23 will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 83
All Time: 110,676
