0
Score
Avatar
XPI77
Asked
MBP not starting up after disconnecting battery from logic board?
History
So yesterday my macbook pro was working perfectly fine nothing wrong with it at all but after i followed the guide on ifixit.com to upgrade ram the computer would not start up unless it was plugged into the magsafe adapter. The led on the charger is always green which i think means that the battery isnt being charged. when i am able to power it up while its charging, in the menu bar the battery icon has an X over it and says no batteries available power source: power adapter.
please help asap as need this computer for school!!
also i have already tried smc reset and pram resets but nothing changes.
Edited by: mayer ( )
Post Answer
Score
Avatar
mayer
148.6k
Answered
PermalinkHistory
I would first disconnect, then reconnect the battery. What color is the X? Please give us the last three figures of your serial number. Look in your system profiler under memory and tell us what your configuration is now. Download and run Coconut battery and let us know your results: http://www.coconut-flavour.com/
Yes i have tried disconnecting and reconnecting the battery. The color of the X is just black and doesnt change at all. THe last 3 figures of m y serial number is RJ7, my memory is now 4gb total 2x2gb i undid the upgrade after my computer wouldnt start. and coconut battery shows everything gray and N/A.
XPI77,
Apple MacBook Pro "Core i5" 2.3 13" Early 2011 Specs Identifiers: Early 2011 13" - MC700LL/A - MacBookPro8,1 - A1278 - 2419* Symptoms The battery of a MacBook or MacBook Pro computer may: Appear to have no charge (zero percent) Be unable to power the computer by itself; the computer might work only when it is connected to the MagSafe power adapter, which only shows a green LED Appear with a black "X" icon on the menu bar Note: If a red "X" icon appears on the menu bar and the power adapter displays an amber LED, see MacBook, MacBook Pro, MacBook Air: Battery not recognized after being fully drained instead. Resolution Shut down, then remove and reinstall the battery. Test for the issue(s) again. Connect the MagSafe power adapter (if you haven't already) and see if the behavior continues. If the issue(s) persist, download and install the Mac OS X v10.4.9 Update. If the issue(s) persist, download and install Battery Update 1.3. If, after installing the Mac OS X v10.4.9 Update and Battery Update 1.3, a black "X" still appears in the menu bar, follow the steps in MacBook, MacBook Pro, MacBook Air: Battery not recognized after being fully drained. If the battery charge status still shows zero percent, yet appears to show a nearly full charge shortly thereafter, see Calibrating your computer's battery for best performance. http://support.apple.com/kb/TS1457
mayer,
0
Score
Avatar
Jaehoon Lee
Answered
PermalinkHistory
Same problem here.
I recently upgraded my RAM and HDD to SDD.
I plugged out the battery before I changed them.
After that, no batteries available sign on my screen.
I bought a new battery, and it is still the same.
Any solutions??
Add Your Answer
