Score
Avatar
Spikey2
1.2k
Asked
silent switch and 'volume up' not working
History
Is there a way (that has a chance of success) to get the switch and 'volume up' button working without having to disassemble the phone?
Like spraying contact cleaner in - or would that cause more problems
Post Answer
Score
Avatar
David Iwanicki
2.8k
Answered
PermalinkHistory
The most common cause of failure of these two switches is drop damage. If the aluminum casing is impeding the buttons, you might be able to pry it away from them. If this doesn't resolve the issue, then the switches may have been damaged internally- they are mounted to the rear panel, as shown here:
http://s1.guide-images.ifixit.com/igi/5E...
I would NOT spray any liquid into the iPhone! It is always energized, so you will likely short out the device.
It might be worth the effort to remove the rear panel and attempt to work the aluminum and switches back to their proper shape, and if this does not resolve the issue, the replacement part sold here on iFixit appears to contain new switches:
http://www.ifixit.com/iPhone-Parts/iPhon...
Check with sales support before ordering to confirm this...
Thanks - will look into it and report back
Spikey2,
0
Score
Avatar
mazharkhan11
Answered
PermalinkHistory
my iphone volume up is not working can u tell me the simple way to solve the problem because i can't open it my brother gave it to me as a gift can u solve my problem???
Add Your Answer
