Score
Vee Eight
13
Asked
iPod Screen Stays on Apple yet still functions?
Well around a year and a half ago I had let a friend of mine borrow my ipod 2 days later it was returned to me, I noticed the colors were warped on the screen and it had the connect to battery logo since the ipod hadn't been charged. I got home and restored it yet the ipod was stuck in the Apple logo. I assumed it was frozen so I tried restoring it multiple times. I learned how to put it in disk mode and diagnostics mode and the weird thing was that the screens were clear and it did not seem like any water damage had been done to the LCD. I checked the SMART data and there was and still are 0 reallocated sectors. Months later I turned my ipod on which would always boot up on the Apple logo with the warped colors which it is always stuck on that screen and I noticed after a while I could hear the click wheel. So in a sense it did function, I learned how to count the clicks down to shuffle and how to listen to an album by holding the center button and choosing the Artist, Album, or All songs just by counting the clicks. After a while if the ipod goes to sleep once you resume it you can see the screen as if it were normal for example you can see the menu or album cover but the thing is once it does that it freezes and stays static. The colors are still warped. So I'm really confused as to what the problem may be?
Score
Elisha Bonack
193
Answered
It is either a problem with your LCD Display Screen or your device's mainboard. On the mainboard of your device, there should be making (e.g. 820-1975-A). You should be able to find your correct model and then replace the mainboard, if you want to go that route. Since the classic Firmware is pretty much set, there is no real worry about data, but back it up prior to replacing the mainboard. However, it might be that the data will transfer over just fine, and you won't need the backup.
Again, try the LCD Dispaly Screen first. Second, replace the device's mainboard.
Best of Luck,
Agent Elisha
Edited by: oldturkey03 ( )
0
Score
mark
Answered
It looks like the screen itself needs replaced. Those iPods are fairly easy to repair. Should solve your problems.
I too thought it was the screen but when it is in disk mode and diagnostics mode it functions well and the screen has no warped colors whatsoever. Also for exampled the Do Not Disconnect flashes in disk mode meaning it does not freeze and it shows when you are charging it and not charging it. In diagnostics mode I can navigate easily. The only time it shows problems is when I want my iPod to function normally. If I could post screens shots I would show you.
