0
Score
Avatar
elder norm
Asked
How critical is Dust inside laptop
History
In my desktop computers, dust in the fan and heat exchanger areas is critical but easy to remove.
In a mac laptop (I use an iBook, MacBook and now a MacBook Pro) how concerned should I be vs dust stuck in the heat exchanger area and how do I clean it (air can blowing inside?).
Post Answer
Score
Avatar
mayer
148.6k
Answered
PermalinkHistory
Just watch your heat over the years. It's according to where you live as to how much dust build up you get. Also I've found that households that use a vacuum cleaner a lot are much more subject to dust build up in the machines. The dust stays in the air longer and your machine acts like a filter. Usually a machine is good for four years before you need to get in and clean out the heat sink vents and reapply thermal paste. But I've also seen up to 90% blockage of those vents. So, if it's not getting hot, don't fix it.
Add Your Answer
