Sony Cyber-shot DSC-W5 5.1 Megapixel
10 Questions View all
Can't open battery compartment
I haven't used my Sony dsc-w5 for several years. I am now unable to open the battery comparment. I suspect the battery has leaked and corroded the latch from the inside. How can I open the latch without damaging it?
Score -1
Add a comment
1 Answer
Chosen Solution
charles, you could try and soak the corner with the battery door in a backing powder solution, and/or use a sprayer to try and spray some around the corners. Also, a toothbrush scrubbing might get it loosened. If you soak it, just place that particular corner in a solution, not the whole camera. The only other way is to disassemble the camera, the attached images may help you with that task. Hope this helps, good luck.
Score 3
Add a comment
Add your answer
charles will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 9
All Time: 1,931
