0
Score
Avatar
Leroy
11
Asked
Why is my trackpad clicking at random?
History
My trackpad has been clicking at random lately. I am not sure if I need to replace the upper case or if it could be another issue that is effecting the trackpad. Any pressure put on the top case will cause a click which is very annoying. The button also seems to get stuck in the down position from time to time.
Edited by: Leroy ( )
Is your battery swelling or bulging if you look at it.
Owen Cunneely,
It is actually. Slightly bulging from the bottom.
Leroy,
Post Answer
2
Score
Avatar
Owen Cunneely
2k
Answered
Accepted Answer
PermalinkHistory
Try taking the battery out and see if the problem persists. If it doesn't then you need a new battery. The battery you currently have in there is most likely swelling and applying pressure to the underside of the trackpad.
Hope this Helps
That was it. I knew it was kinda bulging a bit but didn't put 1 and 1 together. Still under warrantee so new one on the way. Thanks again.
Leroy,
If this answer solved your problem please accept it so other can learn from your issue. Thanks
mayer,
Add Your Answer
