The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
49 Questions View all
Question Closed
How do I replace the display card in my Power Mac G4?
The monitor quit showing my 2000 Power Mac G4. I tested it with other working monitors & none of them worked with my G4, but did work on other computers.The G4 does power up. I was told it was more than likely the display card in the computer.
Add a comment
Chosen Solution
You can open it, and remove it using this guide (It's For a newer powermac G4, but the procedure is the same) Power Mac G4 MDD Graphics Card Replacement
You can replace it with a Mac compatible AGP graphics card, or flash certain PC cards, though it deppends on what you do with the machine. If you use an apple ADC display, you cannot use a flashed card. Here are some links to compatible replacement cards(in order from least to most powerful):
ATI Rage 128 (16MB):
http://cgi.ebay.com/Mac-ATI-Rage-128-Pro...
NVIDIA GeForce 2MX (32MB):
http://cgi.ebay.com/Apple-Mac-630-3703-n...
ATI Radeon 9000 (64MB):
http://cgi.ebay.com/ATI-Radeon-9000-Pro-...
ATI Radeon 9600XT (128MB):
http://cgi.ebay.com/ATI-RADEON-9600-XT-1...
NVIDIA GeForce 4 Titanium (128MB, In my one G4):
http://cgi.ebay.com/nVidia-GeForce-4-Ti4...
Flashed Cards:
ATI Radeon 9700 Mac (Flashed, 128MB):
http://cgi.ebay.com/ATI-Radeon-9700-Pro-...
ATI Radeon 9800 Pro (Flashed, 128MB):
http://cgi.ebay.com/Mac-ATI-Radeon-9800-...
Score 3
Add a comment
If you want to go back with original equipment just do a search on eBay apple & component then video & AGP. Here's one for $10.80 with free shipping, Apple Mac G4 ATI Rage 128 Pro VGA DVI AGP Video Card HS. To put it in just remove the one screw holding it in, pull the card and replace. The AGP cards have a small tab on the bottom back end of the card next to th motherboard that you have to push about 1/2 inch to side side to disengage it.
Score 1
Add a comment
Chris,
This is exactly what I needed. This is my first time using iFixit, & I can't believe how fast you responsed!
What a great site! I will certainly tell people about this website.
Thanks Chris, & thank you so much for your time.
Kim Walker
Add a comment
A warning on the APPLE ATI Radeon 9000 Pro.
FYI - I have a factory installed APPLE ATI Radeon 9000 Pro in my MDD Mac, and when running OSX 10.4.11, my machine crashes when waking from sleep. It may be Video sleep, or machine sleep, or both. So I turn off hardware sleep, and all is well.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,917
