0
Score
Asked
Coffee spilled on MacBook Air 13"
Some five days ago (June 4th), I spilled a coffee cup on my Macbook Air 13" (1.8 GHz, Mid 2011) keyboard and its shut off immediately (11am). After 6 hour of drying with AC conditioner (17pm), the MBA turn on and no problem with the system, because I worked with it.
However, at night (21pm), when charge is off, I put the charger and the indicator light charger was not orange (like discharged), but green (like charged). Well, now (June 8th) I think that my MBA does not recognize the battery, because the charger light in green is kept. I believe the only water damage was on battery.
I would like to know how to evaluate the real state of my MBA, before sending to technical service (very expensive) and I would like to know if I could repair myself.
In advance, thank you very much.
Guillermo
2
Score
nick
15.3k
Answered
You have to clean the computer before you go any further, so the coffee is not a variable in the troubleshooting process
You will need to take the whole computer apart tough, so keep this in mind
Here is a list of parts to keep out of isapropal alcohol
battery(best to replace it just in case)
fan
Upper case
cables(to clean the cables, just dip the toothbrush in the alcohol and clean the connections that way)
As to cleaning the boards, use a toothbrush to help clean it, this works when i do cell phones with loosening dire in crevices
You will need 91% or stronger to clean the computer
Here are the guides you need to take it apart
MacBook Air 13" Mid 2011 Logic Board Replacement
Installing MacBook Air 13" Mid 2011 I/O Board
You will also need thermal paste, a T5 torx screwdriver and a pentelobe screwdriver
MacBook Pro and Air 5-Point Pentalobe Screwdriver
now that the computer is dry, reassembled and clean, it's time to begin troubleshooting
Reset the SMC and PRAM
To reset the SMC, press and hold command, option, P and R at the same time while it is booting before the bong
The PRAM is different on non-replaceable battery computers to reset
Shut down the computer.
Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
Release all the keys and the power button at the same time.
Press the power button to turn on the computer.
Note: The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
From here, you will have to change parts out as you go and keep trying till the right part solves your problem
It's also a good idea to buy a new battery just in case, I tend to suggest replacing the battery no matter what with liquid damage, I worked with a phone, battery bulged, and it could have very well exploded, and I did make her aware of the bulging, I told her to replace it before tough as soon as you can, if you can't afford a replacement yet, watch it closely and see if it acts up in any way that is not normal, when it does, replace it right away
Compatible with the type 5IPR fasteners used on MacBook Air, MacBook Pro Retina Display laptops, and... — 50+ available at 12.95 each.
Score
mayer
148.8k
Answered
What is the status of your battery icon in the menu bar?
Download and run Coconut battery to get an idea of what's up with your battery and let us know your results: http://www.coconut-flavour.com/
0
Score
Answered
