0
Score
mike
41
Asked
Radiator Fan not working.
How can i test my radiator fan to make sure it is working correctly.
Score
oldturkey0
88.5k
Answered
Accepted Answer
mike, you can disconnect the fan motor plug from the relay, and supply power and ground to the fan motor directly. If the fan runs, you probably have problems with the relay or the temperature sensor. The temp sensor is just below the thermostat in the lower thermostat housing near the power steering pump. The attached diagram show you the wiring for our Volvo> Hope this helps, good luck.
0
Score
mike
41
Answered
Thank you so much oldturkey 03, the radiator fan is now working,you are magnificent.
