0
Score
Avatar
tony tony
71
Asked
replacing battery, bottom logic board overheats
History
I have a ipod touch 4 that has a dead battery.
I tried to replace the battery and made sure that the contacts are not bridging... however once I solder the +, ground and negative contacts the board starts to get really hot! i immediately de-solder the battery.
Is the battery bad?
What would cause the board to heat up? thank you.
Edited by: tony tony ( )
Also I am able to power the device on via usb cable and it works fine.
tony tony,
Post Answer
Score
Avatar
oldturkey03
87.9k
Answered
Accepted Answer
PermalinkHistory
tony tony, definitely check on your soldering. It does sound like you are short circuiting something. If your work is done properly , I would suspect you have a battery with a short circuit. Replace it and see if it makes a difference.
I am getting the battery exchanged. I cleaned off the soldering and waiting for the replacement in the meantime. Thank you again.
tony tony,
0
Score
Avatar
Alex
Answered
PermalinkHistory
But I still can't find the processor speed~
Edited by: Alex ( )
Alex, did you post this to the wrong question:-) ?
oldturkey03,
These are 1GHZ A4 processor underclokced to 800MHZ last time i bothered to check
nick,
Does this in any way pertain to the above question? I seem to be missing something....It looks to me like Alex comment was meant for this http://www.ifixit.com/Answers/Ask/iPhone...
oldturkey03,
Add Your Answer
