iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
Why can't my iPod charge?
I've got a very big problem.From time to time,iPod doesn't want to charge..it overheats i f I put it on charge many times,and sometimes it's blank-it shows that I have no music,but that I have 1809 songs,which I do...and it also freezes from time to time....help!
Add a comment
Chosen Solution
Luna, it appears like you are having multiple issues. The overheating can be caused by a bad battery or the power management IC. The files not showing up can be firmware related as well as hard drive issues, so can the freezing. I would start by replacing the battery, reevaluate and see what it does. You can get a USB-to_zif adapter to check the integrity of your hard drive. Run the internal diagnostic test and see if it passes all those. Hope this helps, good luck.
Score 2
Add a comment
but sometimes.i think this is NOT caused by overheating or something.before i have this fault,too.i just have 32 song.it still normal.secong time,i sync with itunes and i have about 10 songs or less.the third time,i syce with itunes too and i have about more than 200 songs.BUT after that,sometimes i try to connect with pc and it can't and now,when i try to recharge by plug into a power outlet(you know it,i think) and it cannot recharge.BUT when i breaking up the source at the ipod source.it charge BUT when you using.it cannot charge.you must turn it stand by by hold the play button for a few second.so it charge.works for me.
Add a comment
Add your answer
Luna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,612
