0
Score
Avatar
Luna
Asked
Why can't my iPod charge?
History
I've got a very big problem.From time to time,iPod doesn't want to charge..it overheats i f I put it on charge many times,and sometimes it's blank-it shows that I have no music,but that I have 1809 songs,which I do...and it also freezes from time to time....help!
Post Answer
Score
Avatar
oldturkey03
88.1k
Answered
PermalinkHistory
Luna, it appears like you are having multiple issues. The overheating can be caused by a bad battery or the power management IC. The files not showing up can be firmware related as well as hard drive issues, so can the freezing. I would start by replacing the battery, reevaluate and see what it does. You can get a USB-to_zif adapter to check the integrity of your hard drive. Run the internal diagnostic test and see if it passes all those. Hope this helps, good luck.
0
Score
Avatar
mondagonmon
Answered
PermalinkHistory
but sometimes.i think this is NOT caused by overheating or something.before i have this fault,too.i just have 32 song.it still normal.secong time,i sync with itunes and i have about 10 songs or less.the third time,i syce with itunes too and i have about more than 200 songs.BUT after that,sometimes i try to connect with pc and it can't and now,when i try to recharge by plug into a power outlet(you know it,i think) and it cannot recharge.BUT when i breaking up the source at the ipod source.it charge BUT when you using.it cannot charge.you must turn it stand by by hold the play button for a few second.so it charge.works for me.
Add Your Answer
