0
Score
Avatar
Henrik
43
Asked
I dissembled my iPhone 3G without keeping track of screws!
History
I could clearly seperate the two first screws to open up the iPhone, cause they look so different. Then I managed to seperate all logic board screws, those half threaded ones, and the additional two that has the same length and then the one with the sticker on, though after this I'm clueless. I don't know where to put which screws ... One more, I know the longest one that fits in the headphone thing. Please help me out, where can I find some guide or something that gives me an overview?
Thank you
Post Answer
0
Score
Avatar
mayer
150.6k
Answered
PermalinkHistory
You should be able to review the teardown and identify your screws: http://www.ifixit.com/Guide/Device/iPhon...
Some of them lacks information about screws. "Remove the two Phillips #00 screws securing the on/off switch to the front bezel."
Henrik,
That is the information, #00 is a Phillips screw head size. http://ifixit.com/pdf/guide_583_en.pdf
mayer,
I figured that out, thanks. I'm wondering how many mm it is?
Henrik,
I did the same thing. I wish the guides would have had a tip to keep track of the sizes and mark them.
Birdie,
0
Score
Avatar
step21
13
Answered
PermalinkHistory
You should notice when a screw really doesn't fit. Also, if you lose a screw here or there depending on where it is it doesn't really matter, functionality should still be restored.
I'm not saying that this is true for all screws, but there are screws where it doesn't really matter. Also, the bezel might not perfectly align again anyway, but not due to screws, and if the home button is not really working anymore it is likely due to something else, not because of any screws.
step21,
Well not really, If there are missing screws or not the right size, the I-phone will not be "leveled" and the metal bezel would not be flat. If something doesnt fix perfectly there would be gaps between the bezel and the front cover and then things like, the home button not working or needing to press hard to make it work etc would start occurring. Not good
Birdie,
0
Score
Avatar
Alex
Answered
PermalinkHistory
Try to put your screws in order of when you took them out ... ie. if you took the outside screws off first, put them at the top. Then whatever screw you took out next, put that just underneath, etc. Also, use a fridge magnet to hold your screws so you don't knock them or they don't roll away somewhere.
Also:
http://www.ebay.com.au/itm/MAG-MAT-magne...
This will help in the future.
0
Score
Avatar
Craig
687
Answered
PermalinkHistory
I always draw a diagram of the device on a piece of paper with a circle to indicate where the screws go. An old magnetic sign makes a great screw template.
0
Score
Avatar
gcb
Answered
PermalinkHistory
All screws are #00, so the information on the dissasembly is useless.
There are only changes in the lenght and minimal changes in the tread width.
Also, there's one with a nut that is never mentioned in the dissasembly.
I took mine apart thinking on just using the screen and battery, but then when i found out it's impossible, i'm trying to put it togheter after getting a new connector for the proprietary cable. Will use it as a Pandora receiver in my audio receiver.
To help someone with the same problem in the future, here's the list of screws.
  • 9x short one (1mm x 1.5mm)
  • 2x short and thin ones (0.95mm x 2mm)
  • 8x medium (1.25mm x 3mm)
  • 1x 3mm
  • 1x 4mm
  • 1x brass nut
The short ones are to attach buttons and vibrating motor to the chorme trim
the 8x medium ones are to attach the logic board (incl one on top left to secure mother board AND silent switch)
Edited by: gcb ( )
Add Your Answer
