0
Score
Avatar
ctrc
Asked
iPhone getting very hot after a few minutes...
History
I bought an iPhone from a website. The seller described it as "looping with apple logo"
I received it, and it keeps looping (powering on for 10 seconds and turn off when plugged to the computer). However, when plugged to the house power supply it fully boots. In both case, when I remove the usb, it turns off.
I removed the battery and put a new one ! The iPhone started ! Everything was looking fine.
It was ON for about 10 minutes and I noticed that the part on the left of the battery connector was getting very hot ! I was about to restore to a fresh new firmware but the Home button was not working anymore... (can't get to DFU).
What does it mean ? The iPhone was water damaged (it does not seems to have corrosion trace). But the phone was opened for sure in the past !
Edited by: ctrc ( )
Post Answer
2
Score
Avatar
SIMRAN
2.6k
Answered
PermalinkHistory
dismatle the iphone and remove the shield from the logic board and check the any spillage to logic board . or do one thing remove all the jacks from the logic board except lcd and digitizer and try to power up with usb cable . pls connect the charging flex to logic board after powering up remove that also. now use the phone for while if still hot then it means problem in battery or logic board. if not then try to connect lacks one by one . means put one jack more then use . then one more like this . when getting hot at the last jack . remove that and change it . best of luck
No spillage on the logic board. I tried what you said : Removed charging flex + Headphone jack/volume button cable + Top Microphone/sleep button cable + Front camera cable ---> No heat. Connected Headphone jack/volume button cable ---> No heat. Connected Top Microphone/sleep button cable ---> No heat. Connected Front camera cable ---> No heat. Reconnected the charging flex ---> Heating up fast !!
ctrc,
What does it mean ? My battery is new (I took from my new iPhone 4). And also, the Home button is not working since the last time (see first comment)
ctrc,
you have to change the charging flex . that makes the iphone unstable . remove the speaker from the down side of the phone and there must a liquid damage to charging jack . took out that and clean it properly . if works after thats gud if not then change it . see the jack looks like http://www.ifixit.com/Guide/Installing-i...
SIMRAN,
if solve accept it thanx
SIMRAN,
Thank you for your answer. I am ordering this part right now. What do you think about the Home button ? Changinf the dock connector will also reactivate the home button ? I will Accept it as soon as I can try the new part."
ctrc,
Show 7 more comments
0
Score
Avatar
vj asad
Answered
PermalinkHistory
i have iphone 4g when i conect charging the phone on but power button not work and toshiba main chip heat i m also change bettery but problem same ...anyone solve this,plz help
Update
Edited by: vj asad ( )
Add Your Answer
