0
Score
Avatar
omer
11
Asked
device get hot after screen replament
History
hello
i have ipod touch 4th.
it was 100% work before i opend it to change screen.
(its not my first time that i changed screen to itouch 4th).
now, after i closed the device, he wont turn on, and get little hot.
i try to do hard reset - nothing
i try to enter DFU mode - nothing
compunter not recognize the device, usb failure
i changed the cable couple twice (all original apple usb cable),
i try to change port
i try change computer - nothing..
device still get hot, and nothing happen
not hard reset and nothing....
anywone know what can i do?
which steps i need to check?
non of the cable are damaged, all clear
i also try to replace again the screen with the old one, to see if it helps, but nothing...
please help :)
many thanks!
My email: omer.benatia@gmail.com
anyone?
omer,
omer, you say your device is getting hot, and I would check to see if there is a specific area that gets hottest. The most common part to get hot would be a IC, and most commonly it would be the power management IC. I would start with disassembling the iPod and taking some voltage measurement at the dock connector, and at the battery. I would expect it to get around 3.7V at the battery contacts. It is possible that you have a faulty battery that cause the IC to overheat, or vice versa. Let us know.
oldturkey03,
oldturkey03 thanks 4 your answer the whole main board get hot, not one ic.. maybe i need to disconnect the battery with solder iron?
omer,
Post Answer
0
Score
Avatar
omer
11
Answered
PermalinkHistory
anyone....?
0
Score
Avatar
Harolyn
Answered
PermalinkHistory
Omar,
Did desoldering the battery help? I am having the same problem with my ipod. Wondering if battery was the problem.
Add Your Answer
