0
Score
Avatar
Yannis Tsokanis
Asked
Not charging water damaged but working
History
The iphone was dropped in water and now it can't be charged. It is fully functional though so I am looking what it should be replaced in order to reenable the charging function.
Post Answer
2
Score
Avatar
oldturkey03
87.7k
Answered
PermalinkHistory
Yannis Tsokannis, I most certainly recommend that you will have to clean it in order to prevent later failure due to corrosion. Check this guide. It was written for a 3G but applies to your phone as well. Clean it thouroughly or risk failure later on;-) The LiIon battery absolutely do not like any humidity and can even react violently with it. These are smart cell device that will have to be replaced due to the possibility of a short circuit. Clean your phone, replace the battery and re-evaluate for any damage. you can get the battery from here iPhone 4S Replacement Battery If after that it should still not charge, you may have to start replacing the dock connector. Hope this helps, good luck.
Product Image
Replace that dying battery or carry an extra for backup power! — 50+ available at 29.95 each.
Add Your Answer
