0
Score
Avatar
Mark Pence
Asked
Phone washed, after drying wont run on battery.
History
Will getting wet ruin the battery?
Phone went through complete wash/rinse cycle, found when moving clothes to dryer. I took out SIM and battery, blotted dry and set it in front of a fan for two days. The fan was not a hard blow just a good bit of air movement.
Put it back together and plugged it in to wall charger. Phone booted to lock screen saying it needed to be activated. I unlock it and it has the usb cable plug me in graphic. But it keeps rebooting shortly after getting to lock screen (about 20 seconds).
If I disconnect from power it shuts off like batter is dead and will not do anything without being plugged in.
It will not boot to lock screen plugged into USB only wall outlet. USB gets the Apple logo a bit then turns off then repeats.
Home, power and screen all work fine.
Kinda seems to be in DFU mode like OS install is hosed.
Thanks for the info, even on a Sunday! I have it apart and back in front of the fan for a couple more days. I will replace the battery after cleaning it all and see how it goes.
Mark Pence,
Post Answer
0
Score
Avatar
Skippy722
2.1k
Answered
PermalinkHistory
You should have left it too dry a bit longer than 2 days, closer to a week is recommended. I recently dropped my cell into a toilet and I put it into a bag of rice for 5-6 days and it booted right up, the screen was just blotchy. To me, it sounds like you might have fried something/shorted it out turning it back on so fast. Oh, I also dropped my ipod tough 4g, now the battery life absolutely sucks on it. So yes, getting it wet can ruin that component.
0
Score
Avatar
oldturkey03
87.9k
Answered
PermalinkHistory
Mark Pence, as with any device that got submerged, you will have to clean it in order to prevent later failure due to corrosion. Check this guide. It was written for a 3G but applies to your phone as well. Clean it thouroughly or risk failure later on;-) The LiIon battery absolutely do not like any humidity and can even react violently with it. These are smart cell device that will have to be replaced due to the possibility of a short circuit. Clean your phone, replace the battery and re-evaluate for any damage. Hope this helps, good luck.
0
Score
Avatar
Jack Byrnes
555
Answered
PermalinkHistory
Mark Pence, oldturkey03's right. I just helped fix my friend's iPhone 4 that took a swim in the ocean. What I did to clean out the sea water and corrosion was to submerge the whole phone (minus the battery) and later the logic board only in 99% isopropyl alcohol. That will help clean the contacts and draw the water out of the iPhone. I left the phone in the alcohol for about 1 day. It works perfectly now - I have been testing it for days and it is just as new. As for the battery, I think you'll need a new one. They're only $25 at iFixit, so it isn't too much to swallow. I put a link to the battery:
iPhone 4 Replacement Battery
Product Image
New replacement for GSM and CDMA iPhones. — 50+ available at 24.95 each.
Add Your Answer
