Score
LymanSS
13
Asked
Water Damage - home button no longer works
A friend fell into a lake while holding an iPhone. Everything works fine except for the home button. I've disassembled it and tested the button mechanism itself and found that it works fine. Resistance across the button's two contacts drops to zero when I press the button. So I suspect that the failure isn't in the button mechanism. I found the contacts where the button connects to the board and tried bridging them to simulate the effect of pressing the button and closing the circuit. This has no effect. I didn't want to tear down any further without more info. Any help would be greatly appreciated.
Score
David Iwanicki
2.8k
Answered
Check the circuit board on the dock connector, and cable #4 for corrosion. If you have another dock connector board, try swapping them around - hopefully the issue hasn't spread to the main logic board.
0
Score
Spikey2
1.2k
Answered
I would do a full reset on the phone - if you have not done so.
This did the trick on my phone, when battery consumption was high despite all services being switched off.
0
Score
mobileease
37
Answered
It sounds like you have a damaged dock. I have replaced hundreds of these parts and the home button is very temperamental. I am not sure where you can get home button.
Try silica desiccant.
Water damage is very difficult to diagnose as it can seep into different parts of the phone. you are lucky it has not damaged any of the power management chips.
good luck anyways
0
Score
Answered
almost same story but i opened the phone and was trying to clean the two prongs and the broke off how can i replace that? im looking at the man and i dont see instructions on that part. thanks
0
Score
Answered
0
Score
Nicholas Ouimet
562
Answered
0
Score
Answered
0
Score
mobileease
37
Answered
0
Score
Answered
0
Score
Answered
I have a 3GS that was water damaged and the home button no longer works. There seems to be an issue with the board though as swapping buttons and docks out did not do the trick. Something must have been damaged internally because no amount of alcohol baths on the board is resurrecting it.
0
Score
Rich
49
Answered
I have a 3GS that the home button circuitry shorted out on. I was able to determine that the short is somewhere on the motherboard. Rather than pay to get my phone fixed I jail broke my phone and am able to use an app called the activator to use screen gestures to simulate a home button press. This was by far the easiest route for me. I used jailbreakme.com which was very straight forward. Note you'll need to have java enabled for you to be able to use this website. I believe if you haven't updated past OS 4.0.1 then it should work.
0
Score
biiiiio
Answered
This invention saves Home Button from water damage from the surface:-
