0
Score
dylan
31
Asked
360 cd drive reading games as dvds
I fixed RROD on my console, replaced the cd drive with a working one from another console and it wants to read games as dvds. Anyone know the solution to this? Any help is much appreciated.
2
Score
oldturkey0
87.9k
Answered
Accepted Answer
dylan, couple things that I would try. First I would suspect a dirty laser. You can buy a laser lens cleaner disc at most hardware stores. If they are not available in your area, you can, take the drive apart, use isopropyl alcohol to clean the laser really good using cotton swabs. If that does not work for you, you can try to do a "pot adjustment" Check on here for that. If that does not work, and if you are having the right drive key, you may have to replace the drive with a new one. Just remember that the drives are mated to the console and require that you have the right key. There are plenty of sites that will tell you how to do that. Hope this helps, good luck.
When you replaced the optical drive, did you transplant the PCB from the old to the new? Did you clone the drive key any other way? remember "The Xbox 360 is designed so that the DVD drive works only with the particular game console it is installed in. Replacing a defective DVD drive with a replacement DVD drive does not work, since the replacement has a different DVD drive key, which the game console won't accept." from here
oldturkey03,
Thank you for accepting my answer, good luck.
oldturkey03,
