0
Score
Avatar
Garrett Fletcher
Asked
iPhone 4 Won't Turn On After Attempted Restore
History
For the past year, my iPhone 4 locks up every now and then (it does not let me slide to unlock) but it always began to work again after 4 or 5 force restarts. A couple days ago, this happened, but it did not work after many force restarts. I restored it to factory settings, and I got to the part where it says to let your phone restart, but after it did, the iPhone turned off and now it will not turn back on. iTunes cannot see it and I have tried charging it and it does not work. It had iOS 5.1.
By the way, the phone hasn't been damaged or dropped in water or anything like that.
Garrett Fletcher,
Post Answer
0
Score
Avatar
Deano
407
Answered
PermalinkHistory
What happens when plugged into mains power? Your Battery main have just DIED or at best gone fully flat. Which can only be recovered by the mains power. Do you get a flashing red Battery symbol with a lightning bolt? Leave for 1 to 2 minutes to see if it gaining a charge and pull the plug. If it shuts straight off then time for a new Battery.
You can purchase from here.
iPhone 4 Replacement Battery - Does not require soldering
I hope that gives you some direction.
Product Image
Replacement 1420 mAh battery for iPhone 4. Compatible with all iPhone 4 GSM and CDMA models (Not 4S). Does not require soldering. 3.7 Votls (V) / 5.25 Watt Hours (Whr). — 15 available at 19.95 each.
Yep that was it. Thanks, but now it is at the iPhone startup screen for setting up a new device, and it still freezes when I slide the slider.
Garrett Fletcher,
0
Score
Avatar
Ben M
Answered
PermalinkHistory
I'm having the exact problem. Did you manage to find a solution?
0
Score
Avatar
mckenzie
Answered
PermalinkHistory
im having the exact same problem . ive tried holding down the home and power buttons but it doesnt work
Add Your Answer
Today: 10
This Week: 29
This Month: 202
All Time: 8,701
