0
Score
Toby
35
Asked
No LCD backlight on my MacBook Core 2 Duo
My MacBook's backlight doesnt work, i can see the screen when i hold it at an angle towards the light and it works perfectly when connected to an external monitor. The wierd thing is, that the backlight comes on for roughly two seconds when i power on the MacBook, but only the right half of the screen is lite up and there are about 6 different coloured vertical lines over the screen.
i did a tear down on the machine, i flexed and moved the inverter/data cable around, no change in the backlighting situation so i dont think it's any of the cabling. I also removed the inverter board at one point and the lcd screen was still on.. just no backlight of course. So i dont think it's a problem with the LCD or cabling.. but im not too sure. Does anyone have any suggestions?
Someone please help me solve this! email me at tobykake@live.c
0
Score
lemerise
15.2k
Answered
Accepted Answer
Replace the inverter cable and the inverter board. If it doesnt work then the backlight or the LCD panel is the problem.
Hi, i replaced the inverter and cables. It was the inverter that was the problem. Just another problem now, the wifi has very very weak signal. if cannot connect unless im literally right next to the wireless router.
Toby,
Score
chris206
13
Answered
Sounds like the airport antenna (wires that run the bottom and side perimeters of the lcd) may have been left disconnected or been cut. My only thoughts are to remove the keyboard (following proper procedure) and confirm that your airport card has its cables connected - usually a white and black clipon pair of wires that lead up to the display. Also there's a possibility that these wires got pinched or severed when replacing the white hinge clutch cover.
0
Score
tommywrigh
11
Answered
Before tearing into your machine like I did, check the brightness control for your screen in system preferences,dis
0
Score
Answered
