Model A1320 / 8 or 16 GB capacity
156 Questions View all
click wheel unresponsive: can I replace with 4th gen wheel?
I have a dead nano 4th and an unresponsive click wheel on a 5th.
Resets doesn't work (as no clicks at all).
Q1) Do 4th and 5th have compatible click wheels? Can I try to replace?
Q2) Any 'tricks' I should try before attempting to replace? (heard about a 'credit card' trick?
Thanks
Score 1
Add a comment
1 Answer
Chosen Solution
albidani gaibazzi , no, it does not fit. The click wheel of the 4th is larger than the 5th and not as far recessed. Try to turn the hold switch off and on a couple of times. If that does not make a difference, you will have to replace it with the right click wheel. iPod Nano 5th Generation Click Wheel Replacement Hope this helps, good luck.
Score 1
Add a comment
Add your answer
albidani gaibazzi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 920
