0
Score
Avatar
waltondennis18
Asked
My Xbox 360 goes straight to two solid red lights
History
I did the x clip fix and still goes 2 the solid 2 red lights
Post Answer
0
Score
Avatar
oldturkey03
88.6k
Answered
PermalinkHistory
Since you have had it apart, I would strongly suggest to double check your work. Make sure that the thermal paste is properly applied and that your heatsink makes good contact. Tighten the screws properly and make sure that you have a snug fit. Amazingly enough, there is no information about solid lights. Check on here and see if you can get the secondary error code. It will help you to narrow down your error.
0
Score
Avatar
kel
Answered
PermalinkHistory
If you don't put the spongy pads back on the four chips underneath the motherboard you will have two rings. If you don't have the pads you can use a rubber brick eraser and cut four pieces about a quarter of an inch of thickness and and tape tem to the chips.
Add Your Answer
