0
Score
Avatar
jahtav
Asked
Why does it only work on a charger?
History
my psp go is not turning on and the charging light wont come on either....only when i plug the charger into it and play it will turn on ........if i remove the charger it turns back off.....help pplzzz
Edited by: oldturkey03 ( )
Post Answer
2
Score
Avatar
oldturkey03
87.9k
Answered
PermalinkHistory
jahtav, sure sounds like a bad battery. It appears like it does not hold a charge. Of course, make sure that the contacts are clean etc. Follow this guide to change your battery. You can get a new battery from here Sony PSP Go Battery as well as many other places. Once you replace the battery, and it still does not charge, you can check the fuses on your logic board. Check those for continuity with a multimeter. Hope this helps, good luck.
Product Image
Sony PSP Go Battery
3.7 V, 930 mAh Lithium Battery — Currently out of stock.
0
Score
Avatar
sameershafique
Answered
PermalinkHistory
Use the spare chager
Add Your Answer
