I dropped my iPod touch in the bath.Tub.Now it won't turn on what do I
Please help me. My ipod touch wont-work cause I accidentally dropped it in the bathtub.
@jacob99147 you are not telling us what model Touch this is.
You will need to treat it as you would any other water damaged device. For now stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your iPod phone using these guides iPod Touch You need to select the right model Touch so you get the proper information on how to disassemble it. Remove the logic board from the iPod.You must remove all EMI shields from teh logic board. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for an Apple iPhone 3G, all the points are still pertinent to your iPod. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your iPod and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 10
