0
Score
Avatar
William Johnson
Asked
My Dsi XL turns on then off.
History
The lower screen flickers before turning off but the top one does not. Any ideas on what might be the problem?
Logic board maybe?
hello,
Post Answer
Score
Avatar
oldturkey03
88.2k
Answered
PermalinkHistory
William Johnson, if you are sure that your battery is charging and holding a charge you may want to check the LCD's and the cables, especially to the top screen. Those do have a tendency to break." If the top LCD ribbon cable is damaged or not connected properly the blue power light will turn on briefly and the bottom LCD screen will flash on very briefly when the power button is pressed. If the bottom thin LCD ribbon cable is damaged or not connected properly the blue power light will turn on briefly and the top LCD screen will flash on very briefly when the power button is pressed." In your case, since the bottom flashes, replace the top screen, check the cable and the hinges as well. Hope this helps, good luck.
Add Your Answer
