Score
sean stevens
23
Asked
Power supply directly over battery connector
Hi,
My Macbook has got a issue on the logic board and so the battery is not charging over the normal power supply but it is working fine with the battery. My question is if it is possible to connect the power adapter directly to the battery connector.
If this is possible, could somebody tell me which of the 7 cables of the battery connector are the right ones.
This is my only hope to get my macbook to work again.. So I have nothing to lose if my experiment fails.
thanks for your answers!
Edited by: sean stevens ( ) , Stefano Gigante ( ) , machead3 ( )
2
Score
machead3
21.4k
Answered
Accepted Answer
NO don't do it, here is a safer, easier solution.
If this Answer is helpful please remember to return and mark it Accepted.
Well, seems he has a Unibody, and I don't see it listed in the FastMac device list. On the other hand, I agree with you. It's better searching for ready made external chargers, dabbling with a battery is dangerous.
I don't know if you understood me right. My plan was to remove the battery and to connect the power supply to the plug where usually the battery is connected.
Simon - I understood that, but it wont work, you'd need to build a "black box" to keep the lion battery from catching fire or exploding. For a DIY it's a very Advanced project. A modification, not a fix. IMnsHO it's smarter to buy a device that's been tested and has a warranty than to make your own. Stefano - I guess he's going to run with the case off, or something?
Ok. Got it!! Thx for your answers! It was only an idea. I was a little frustrated after the statement of the apple technician, who told me that i have to exchange the motherboard and i did not want to give up my machine after 3 short years.. The solution with the battery charger is not the right thing for me because then i can use my computer only as long as the battery is full and then i have to charge it again.
Added the correct link to the device. As I learned the hard way, it's important.
Stefano Gigante,
