2
Score
Avatar
Javier Barrera
35
Asked
How do I fix or replace a broken ring/silent switch?
History
I dropped my 3G iPhone on the floor and now the ring/silent switch does not work. Volume is functioning fine and headphones work when in use. I can move the switch back and forth, however, the phone does not switch modes.
Edited by
Post Answer
2
Score
Avatar
Nat Welch
821
Answered
Accepted Answer
PermalinkHistory
There are a few questions on this, but I couldn't quickly find any, so I don't blame you for asking ;). iFixit though, has a guide for fixing this switch. The part you need to replace is the headphone jack assembly.
Edited by
Product Image
iPhone 3G/3GS Headphone Jack Assembly
Does not include vibrator, backing, or switch covers/assemblies.  — 32 available at 49.95 each.
2
Score
Avatar
angelh0124
25
Answered
PermalinkHistory
There is an app called GeneralInfo. It allows you to switch from ringer to silent without the switch. It only cost 99 cents and it works. My switch is still broken but now that I have the app it doesn't matter because I can change it on my phone.
Angel is a GENIUS! I downloaded the app for 0.99 cents and it works! Saved me $80 they wanted to charge to fix the switch
Destin,
Score
Avatar
forum
13
Answered
PermalinkHistory
I don't think it's the switch. I had this happen to and I posted the questions here. When I took it apart, I found they the drop had caused a connector to pop loose. I think it was the one marked #5. It's a super tiny connector. I plugged it back in and everything worked. Might be worth looking at. The instructions are on here, just follow the instructions for taking it apart and look for the #5 connector to be loose.
Go to the "Repair" section of this site and find the repair for the mute switch and follow those to take it apart. Look for that small plug and make sure it's plugged in.
0
Score
Avatar
rab777hp
12.1k
Answered
PermalinkHistory
You'll off course need a replacement, the part you need to replace is the headphone jack, it includes the ring/silent switch.
Edited by
Product Image
0
Score
Avatar
jerrydink
Answered
PermalinkHistory
I've actually had this problem before. I dropped my iPhone 3GS the first week I got it (actually it fell out of my jacket pocket). The switch felt a little sticky, but it still moved both ways. Of course I was mad I had already broken an important feature as the ringer volume doesn't go all the way down otherwise.
Oddly enough about 3 months later, I was showing someone that my silent feature was broken and to my surprise, it worked! I've always wondered what stopped it from working and eventually fixed itself. Judging by "forum"'s answer it sounds like my connector was loose, too. It must have been just loose enough to not work, but still be able to slide back into place eventually.
0
Score
Avatar
Jojo
Answered
PermalinkHistory
I've just done the same thing with mine! (iPhone 3GS)
However, when I squeezed the front and back of the phone together (using thumb & forefinger) it gave it enough pressure to make the connection and the switch started to work again...and is still working!
I think the connection had just worked loose inside.
- It's a quick fix and worth a try!
0
Score
Avatar
Ns Lynch
Answered
PermalinkHistory
Hello people gust had the same thing phone hit the floor and both volume and silent button didn't work and I tried squeezing the phone together by the buttons but only volume button worked as long as I kept squeezing it then I worked out if I lay the phone I'n my hand flat and slap the back and front of the phone at the same time as if I was clapping my hands together fairly hard for a few seconds firmly both buttons now work and all seems good but squeezing it together or any other thing I tried wouldnt make the mute button work but slapping it together hard has sorted them both so hope this helps as I read all your coments and used them to work it out so thanks to u all
0
Score
Avatar
daniel
Answered
PermalinkHistory
does anyone have a vid on how to replace a mute switch i have tried a couple of times but it feels stiff not light a usual
0
Score
Avatar
Erika Kascin
Answered
PermalinkHistory
Slapping my phone between my hands restored the audio ring tone; great tip; thank you!
0
Score
Avatar
Garry
529
Answered
PermalinkHistory
The audio flex cable is probably still good. You need to disassemble the vibrate assembly to place the switch into the housing (it got knocked loose and is not aligned right). Alternatively, the switch sometimes becomes hyper-sensitive and vibrates too much. Just needs to be re-aligned (basically what happens when a new part is put in).
0
Score
Avatar
Matthew Cook
Answered
PermalinkHistory
I refurbish iphones on ebay and the headphone jack, well, sideswitch, is the most common thing to have issues. I'm forever replacing them, but these tricks are news to me! Might save me a bit.
0
Score
Avatar
dave b
Answered
PermalinkHistory
The general info app fixed mine - even re-enabled the switch if you can believe that.
And this is after I went to the apple store and they indicated I would need to replace the phone!!!
Dave
0
Score
Avatar
frikkie cloete
Answered
PermalinkHistory
the switch remains in the muted position all the time
Add Your Answer
