Why won't my n3dsxl read my 3ds game cards
The ds games will load no problem but 5 of my 3ds won't load when inserted the console says no game card inserted all the same reigons.
A couple of ideas:
Remove the SD card and try again.
Blow in the card slot on the system, to remove dust or dirt.
Clean the contacts on the Card, and the card slot.
Remove, and reinsert in many times, and see if the message "There is no Game Card Inserted" flashes on the screen. If it does, that means that the system does recognize the card, it is simply not reading it correctly.
The wording of the description is confusing, however the issue may be a region lock issue, 3DS consoles are region locked and won’t play games from other regions, you can check the region of the console in the settings, and the region of the games on the card. Jailbreaking (CFW) the console would solve all region issues and would be the only fix that I know of.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 20
All Time: 50
