Repair guides and support for top and front loading Whirlpool brand washers.
426 Questions View all
I push the start button it dings but won't come on.
I have a duet steamer whirlpool module # wfw9600Tw01. Had error code F28 would not reset after being unplug for 10 mins tried several times door would not unlock. I took bottom off and found the pull down tab and unlocked the door but it still will not reset. Door continues to lock and will not start cycle. The power button comes on but when I push the start button it dings but won't come on. What can I do
Add a comment
1 Answer
Hi @lisaseydler
An F28 error code indicates a communication problem between the Central Control Unit (CCU) and the Motor Control Unit (MCU).
Here's the tech sheet for the washer that may help.
Go to p.5 error code F28, to see what to check for, that may be the cause of the problem.
It also mentions how to check the doorswitch system in Step.9 of the check procedure.
Add a comment
Add your answer
Lisa Seydler will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 8
All Time: 19
