Score
Asked
Black screen after replacing flex cable. [SOLVED]
[THE PROBLEM]
I ran into an issue in the shop where after replacing the Flex cable every screen I tried was black. The iPod wouldn't even beep when plugged in.
Since I googled the tar for a solution, and couldn,' find one, I'll post what I found for anyone else with the same problem who hasn't been able to find a solution.
The solution is moved below, to the answer so that it can be cleared per request.
Edited by: Country Computer Service ( ) , oldturkey03 ( )
3
Score
Answered
Accepted Answer
[HOW TO FIX IT]
I covered the circuits around the flex cable and de-solder it then cleaned up the pads and soldered on the new flex.
Not adhering to my own soldering instructions, of course I got in a rush and did this without de-soldering the + terminal on the battery first.
In my case, I went back and disconnected the + terminal on the battery and soldered it back on. The black screen went away and the iPod kicks up just fine.
I hope this helps fellow techs that may have found this.
Please use the last paragraph as an answer and accept it to clear the question.
rj713,
Thanks for letting me know guys, I did as you suggested.
Country Computer Service,
