0
Score
Asked
problems with installing the top case
Hi I am trying to install a new top case on my macbook, so am busy removing the screws as per the directions given on this site. So in Step 6 the middle screw does not want to come out; and also the first screw in Step 9. Can someone please assist me with getting these screws out please? I am using the Phillips #00 screwdriver as instructed.
Many thanks
Verne
4
Score
mayer
150.7k
Answered
I found out by accident that a larger diameter screwdriver handle really makes a difference in how tight I can get screws. The one on this driver set tightens or loosens those hard to budge screws much better than the smaller handles do and is pretty cheap: 26 Bit Driver Kit
I am using the screw driver prescribed by this website for working on taking the top cover off the macbook - phillips 00# screwdriver.
thanks to all of you for the help. I have been told that a screw extractor is not easy to use. Is there any info on how to use a screw extractor? I used a phillips 00# screw driver to take out screws initially. Now some of them wont come out so I was thinking of buying the screw extractor. So can any of you help me with this please or should I just buy the 26 Bit Driver as I might be able to take out the screws with that? Many thanks
Again - it's the diameter of the handle that makes a lot of difference in the amount of torque that can be applied to these small screws. If I tighten one down well with the driver first mentioned, I cannot get it out using say the driver from this kit: http://www.ifixit.com/Tools/54-Bit-Drive...
I gather that you all know by now that I am a female hence I dont know about these things. So would you advise that I get the 26 Bit Driver Kit or Screw Extractor Set please? thanks
Score
machead3
22.4k
Answered
Try one of these. You'll find other possible answers by clicking the tag to the right.
If this Answer is helpful please remember to return and mark it Accepted.
Thank you for the response, but this computer has never been opened before so how is the screw stripped? I have never done this before its the first time I am doing this so I dont understand. Do I really have to buy this screw extractor set for two screws, isnt there an easier or cheaper way pleeese? Thanks
I only know what you told me. Either you don't have the proper screwdriver, or it's frozen/stripped
"You are in the self-help volunteer forum.'' Please direct your question to iFixit support.
When the screws are removed for the first time from a computer you need to have the right tools (screwdrivers) and apply a little more pressure to remove them cause they are are stuck in the threads by a blue adhesive called loctite which is a threadlocker stuff. It prevents accidental loosening due to use and vibration.
lemerise,
