0
Score
chaise
Asked
How do you fix the Blue Inductor Coil on iPhone 4?
ok so i have an iphone 4 and after it was droped the screen broke and my wifi was weaker so i pland to fix the sreen and just redo all the glass as red and the fram as black and well replacing all that i put a new wifi antenna in to see if that would fix the weak wifi well i did not, and now just this week i now have no phone service and still weak wifi, i looked up online and some one said that the blue coil by the wifi and battery plug could have broke, i looked and i think it may be i found the part i need to fix it online. is there any way you can put something up to show how to replace it, thank you
Score
Answered
Yes chaise if you have No Signal or No WiFI on your iPhone , you likely to be on the right track with the famous blue Antenna coil.
Do you have a weak signal or low bars and poor WIFI. I've seen this when the iPhone 4 has taken water damage you may find that the on the reception stops working.
Many times when folks open their iPhone 4 it is easy to break the blue inductor, and then have a weak signal.
The blue coil fixes both GSM and WIFI faults. You can find out more and purchase one here.
Edited by: Adrian Woodward ( )
0
Score
Answered
you can replace it with a new blue iphone coil that will fix the problem
you can buy a new blue coil here for the repair
Edited by: cyberdoctormd ( ) , oldturkey03 ( )
0
Score
johnkustic
199
Answered
I usually just create a jumper with soldering iron and it works.
@ Johnkustis, do you just basically bypass the coil all together? Is that not bad? Or do you just temporally bypass it to see if the coil is at fault? Sounds like mine has gone too, any help would be awesome. Thanks, Chris.
Ok thanks for the replies. I'm gonna go ahead and change the coil. Just a heads up now, Those people selling the replacement coils are robbing people blind.
0
Score
K K
Answered
0
Score
dan
Answered
0
Score
7Gnosis
47
Answered
hello DEAREST friends!! PLEASE HELP me
how can i jumper it ? please ?
recieved iphone 4 after water damage with erro -1 in itunes
now its fixed
but constently losing wifi/gsm signal
the phone has imei and all ,please help me if you can
with what wire can i use to jumper it,its too close to another fuse ,
you saID YOU made a jumper with soldering iron ,since its too small i guess you only implemented soldering iron and thats it ?
can it also be the bb or other coil?
can you please answer me ?
0
Score
Answered
The answer to your questions, how to fix the blue inductor coil causing a signal problem, the solution is easy we have repaired many with a 100% success rate. If you look at the signal antenna which you plug the cable into, simply run a wire from the left side bridge it to the right side point on the blue coil and follow it all the way to the furthest (right) component on the top left side. This will act as a 'bypass route' and your signal will start to work again.
All it takes is a bit of micro-soldering knowledge and some 0.1mm wire and basing soldering equipment. This will fix your problem guaranteed, providing it was the missing blue coil that caused your signal issue in the first place.
Kind regards,
Ideal mobiles
