Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2266 Questions View all
Home button works but digitizer doesn't
When I separated the screen from the phone, I used a plastic spudger as usual, and when I reassemble the screen, the touch stopped working.
However the home button still responds.
I inspected the wire for the digitizer and home button and it doesn't seem damaged in anyway.
What could've gone wrong?
I passed that spudger from the bottom of the phone to the top.
Is it possible that I severed or damaged only one part of that wire?
Add a comment
1 Answer
totally possible (tiny unfortunate tear, not easily seen)
more likely and easy (enough) solution:
re-seat the connectors
pita remove front assembly, remove cables, re-snap them back on (I like a good click, then a sort of tiny swirl push, not as much as getting fingerprinted!)
then, before you re-double sided tape that back, turn on and test (front assembly does jot have to be glued back to work); if all well, then stick it back together!
hopefully makes sense, and good luck
(and if you fail, it may be possible for the genius bar (apple store), to backup without working digitizer)
Add a comment
Add your answer
Alex222 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 24
