Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
Question Closed
Replaced right hinge clutch, computer won't startup
Okay. I'm no noob at these kinds of repairs. I followed the excellent guide at this site for the repair and easily kept track of all screws, didn't break any tabs or connectors, etc. But now that the computer is back together, it won't start up. The optical drive receives power, the hard drive spins up, and that's it. No startup sound. Nothing on the LCD. No backlight. I even took the keyboard off to double check that all internal connections were correct and intact. I even attempted to reset the power management, just in case that would magically fix something, but heard no startup sounds to indicate it worked.
The only thing I can think of is that this is my wife's computer, and she hasn't exactly been gentle with it. Lots of damage to the external case. Could it be that opening it up exacerbated a preexisting crack in the motherboard or something? It's just that the internals looked okay, and I can't detect anything I might have done to cause this! Let me know what you think. Any help is greatly appreciated!
Add a comment
1 Answer
Chosen Solution
A good place to start is triple check all the connections. I know it is a PITA. Then pull out and reseat your RAM. Please let us know the results. After that it will be removing everything that isn't necessary to boot without hurting the motherboard and seeing if you can get the chime (Apple sound). Then verifying the RAM and RAM slots. Then adding back one thing at a time after you have the chime until you find the problem.
Score 2
1 Comment:
Very sound suggestions. +
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 379
