My black E7 headphones won't play any sounds
The lights turn on but it won't play any sound
Hello, after doing some searching, I've found that it may be a bluetooth connection issue. What this means is more than likely an issue with the device you're trying to connect to instead of the headphones. I would recommend checking if all your software is up to date or a simple reset should do. If the problem persists, then I would recommend following this troubleshooting guide. I hope this helps!
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 82
