Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
Why isn't my hard drive being recognized and lcd not lit? help!
Hey Guys,
I recently had the great idea of trying to get my old MacBook 13" 1.83GHZ Core Duo back into commission. I went out and bought a new hard drive because the hard drive seized up a while ago and i didnt have money to replace anything. I ordered a new battery and power supply from amazon and that's on the way. For the time being I can use my dads macbook charger to power my macbook.
When I plug in my computer and power it up, the lcd powers up and the backlight powers up then the backlight turns off. So I hit the power button, gray screen turns on powers up, then backlights off but the folder with the ? comes up. (New hard drive so i figured that'll be normal.) That's problem number 1.
Since I have the new hard drive, I figured I have to re format it. I popped in leopard start up disk and went ahead to select language. I agreed to terms and brought up the screen where I choose destination, but my hard drive isn't recognized. It's spinning so it's powered but not registering. What do I do?
Add a comment
1 Answer
Chosen Solution
You need to format it using disk utility on the leopard start up disk. Once you format using disk utility it will be recognized for you to install Leopard on to it.
Score 2
3 Comments:
How do i do that? I cant find the disk utility anywhere
by
nevermind. found it haha. Now I just have to figure out the backlight issue
by
Glad you found it and it worked for you. Hopefully someone will be able to help you with the backlight issue.
by
Add a comment
Add your answer
OgCorndogg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 629
