Repair guides and support for motorcycles manufactured by Suzuki Motor Corporation.
128 Questions View all
Why doesn't the speedometer or any lights work on my bike?
I have a 1998 Suzuki Intruder 1500, the bike will start and run without any issue, but it isn't getting any lights(high-low, turns, brake) and the speedometer and accompaning lights aren't working either. I just replaced the battery and the main fuse relay is fine as well. The only thing of note is the turn signal fuse is popping.
2 Comments:
I can't say anything about this bike, but on two separate occasions I've had clients bring to me dash clusters from their vehicles, and I found a fault on the ground pin of the main connection. After resoldering those pins to the PCB, dash board worked properly again.
Can you remove your dash to inspect if it is something similar?
by
I'll check it, the cluster isn't that hard to remove. I've had some mechanics I know saying the ignition might be the issue, gonna replace that and see.
by
Add a comment
1 Answer
You have to change speedometer gear in front alloy wheel, check the battery is it working properly or not for lights.
Add a comment
Add your answer
Austin Leonard will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 78
