A 20" monitor released in March 2012 by Acer, model S200HL
7 Questions View all
Help! My monitor has a white filter over it and I can't get it off
I powered my laptop on and the monitor that it's connected to has a black dead spot on a portion of the screen. While I load up a game, the screen now glitches and it the screen is color inverted and washed with a white filter I can't get rid of.
Add a comment
1 Answer
Hi @alberteinst8428,
White filter sounds like the Contrast setting is adjusted too high.
Have you tried a different video cable, vga or DVI (you didn't specify what type of connection)?
Have you tried using a different monitor, just to prove that the problem is in the monitor and not the laptop?
If you've tried another video cable or even a different input type and it still fails, but it is OK when using a different monitor, it may be simpler to replace the mainboard in the monitor than trying to fix it.
Search online for Acer S200HL mainboard or 3520-0052-0150 to find suppliers that suit you best.
Here's the ifixit Acer S200HL LCD Monitor Motherboard Replacement guide that may help.
If you're interested here's a link that although your monitor doesn't have the same symptoms, shows some components e.g. capacitors (check for domed or leaking), that may affect the operation. Worth looking at first perhaps.
Add a comment
Add your answer
Albert Einstien will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 27
All Time: 200
