0
Score
Avatar
Michael Ferrari
Asked
LCD Backlight still not working after replacing inverter board + cable
History
My MBPro works with an external monitor and I can see what's on the screen with a flashlight. I've read all the answers that i could find on the topic here on Ifixit.com and I've replaced the inverter and the inverter cable but I'm still having issues. I've also booted off another macbook to rule out it being a software issue and have reset the PRAM. What is wrong? Is it an issue with the I/O board or actual screen? Thanks so much for the help!
With your external monitor working, your logic board is probably fine. You say you are having "issues" but don't say what those issues are. This makes it just guess work to diagnose. Please elaborate on your "issues".
mayer,
The computer boots up fine and the OS is fine but I can only see a very faint image when I look from the side or use a flashlight. The apple logo on the back of the computer isn't lighting up either so I'm assuming it's a backlight issue.
Michael Ferrari,
Post Answer
3
Score
Avatar
wes
521
Answered
PermalinkHistory
It sounds most likely to be an issue with your LCD Display. I would try an SMC reset first though. I'm not ruling out the possibility of a Logic board fault - but it is cheaper and easier to try replacing the display before the board.
Did anything cause the issue or did this just develop?
Wes
Thanks, I'll try an SMC reset. I bought the computer from someone else so I'm unaware of the history. If I were to buy a new display, can i just buy one one ebay (are they any good?) or should I buy and entire replacement assembly just in case it was another issue?
Michael Ferrari,
0
Score
Avatar
baboba
25
Answered
PermalinkHistory
LCD back light problem ,if you follow the truble tree it will be alot but you have to chack the power inventer in your laptop
0
Score
Avatar
jsteffen70
Answered
PermalinkHistory
I also am experiencing these issues with my MBP A1211 and replaced the inverter but suspect it may be the inverter cable that's faulty, could anyone help me with this issue Please.
Hi it is logic board problem
baboba,
Add Your Answer
