0
Score
Avatar
Sharon
Asked
water on the floor when cycle ends
History
Checked the drain, water didn't come from the drain, the floor at the back of the washer was not wet. The water (looked like) it came out the front somehow.
Edited by: iRobot ( )
Post Answer
0
Score
Avatar
oldturkey03
91.2k
Answered
PermalinkHistory
Sharon, just answered a question similar to yours on here "it is possible that you have an improperly installed drain hose. Check your drain hose installation to make sure that it is properly installed. Check to see if your drain hose is stuck way down the standpipe. If the standpipe opening is taped of, it can cause water to be siphoned out of the washer during the cycle.If water is leaking out of the bottom of the washer, unplug the washer and remove the bottom front panel. Once the panel is removed, check the tub, door boot seal, the hose between the tub and the drain pump, the drain pump and the drain hose. If you need to , you can get the service manual from here and there are more images on on this question. Hope this helps, good luck.
Add Your Answer
